When I push the start button, the motor hums, but doesn't start the drum. I can rotate the drum by hand, so it isn't stuck. Even after two trys for about 1/2 second each, there is an electrical burn smell, so I suspect the motor. Where do I go from here? Thanks
THIS FORUM IS DEAD!!!!!!! |
Thanks Denman,
I tried turning the drum while pushing the start drum and it runs, so looks like the start windings in the motor are bad. I'll be replacing all rollers, idler bearing and belt as a matter of maintenance since it's 9 years old. Have not tried to get the fan off yet, but hopefully it'll come off easily.
Thanks for the help Jerry
Just a quick note, the motor did have an open in the start winding. To anyone replacing the motor for any reason, go ahead and order the blower wheel to save you time, because if it's more than a year or two old, the wheel will be frozen to the shaft and it will not be useable once you get it off.
