my refridgerator is not defrosting I shut it off 3 days ago, I turned it on this morning and the fan is running. Would you happen to know what could be wrong with it?
I assume it defrosted while it was off. Does it work now.If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too. check defrost timer, defrost heater, defrost thermostat Refrigerator Repair Guide: How To Fix a Refrigerator - ACME HOW TO.com
