yanqui
#1 Posted : Friday, May 25, 2012 5:23:12 AM(UTC)
yanqui
doesn't dry but rotates
Simon / APP Team
#2 Posted : Friday, May 25, 2012 9:56:59 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
You will need the multimeter and some basic tools.
First check if there is 240VAC to the dryer.Then, take two screws at the bottom of the front panel and remove the panel by lifting the bottom and releasing the two clips at the top.
Make sure the dryer is unplugged.
Take off one wire from the hi limit thermostat on the top of the burner tube.
Check the heating element for continuity.
If it's open - replace it.
If not - check the hi limit and operating thermostats (located on the blower housing)
For 240V use heater assembly Part number: Y303404
For 208V use the heater coil Part number: W10116793
Here are the breakdown diagrams and Replacement parts for Maytag GDE412 DRYER- ELE | AppliancePartsPros.com
Thank you. Post the results.
Simon.
