My washer will not complete the cycle it stops on the second spin and at times it will not even start the cycle until i turn the knob to find a spot that it will start ( i put it in ultra clean cycyle say 10 min wash pull the knob it just clicks i turn the knob to pre soak pull the knob it start then i turn the knob back to ultra clean and it works untill it goes to the second spin ) and i already jumped the lid switch. Now what??]
Sounds like you never replaced the lid switch.
I would go ahead and put in a new lid switch but that probably will not fix your problem which sounds like a new timer is needed.
Originally Posted by: sidfink43  Sounds like you never replaced the lid switch.
I would go ahead and put in a new lid switch but that probably will not fix your problem which sounds like a new timer is needed. ok ill give that a try thank you
