2 Pages<12
Dohcser
#11 Posted : Thursday, May 24, 2012 7:34:58 AM(UTC)
Dohcser
Thanks, ours start with SH, and that is not in the instructions, so I didn't cut the wire.
Any way to test the evaporator motor?
Dohcser
#12 Posted : Thursday, May 24, 2012 7:46:30 AM(UTC)
Dohcser
Wife just called and stated there is a flap on the top left of the fridge she stated is closed. I presume this is the "air damper", and if so I believe this is probably not working, how can I troubleshoot that?
#13 Posted : Thursday, May 24, 2012 8:15:59 AM(UTC)
If your evaporator motor is running, but the damper is closed, you may have a bad fresh food thermister. You can allways jam the door open 1/4 of the way so your food won't spoil.
Dohcser
#14 Posted : Thursday, May 24, 2012 8:21:37 AM(UTC)
Dohcser
Rich first off, thank you very much for all your input thus far.
Do you know what pins on J1 is the Fresh Food Thermister?
I believe Pin 5 and ? needs to be checked
Also would this cause the fridge itself not to cool?
#15 Posted : Thursday, May 24, 2012 11:52:29 AM(UTC)
You did not have this problem before. Make sure the J2 plug is plugged in correctly.
2 Pages<12
