averushi
#1 Posted : Thursday, March 26, 2009 12:02:35 PM(UTC)
averushi
I am replacing the heater but I am trying to save on the thermostat; how should I test the thermostat?
Please help,
TechnicianBrian
#2 Posted : Thursday, March 26, 2009 4:54:09 PM(UTC)
TechnicianBrian
Safety thermostats can be tested for continuity with a multimeter. A good one will read closed or shorted. The operating thermostat can also be tested with a multimeter, but you would need to get it hot to verify it opens, and back closer to room temperature to verify it closes. If you are replacing the heater, I assume you found it to be bad, so the other components must be working if power is getting to the element.
What are causes of heater thermostat opening ?? (Dryer Repair)
by William Gravett 7/1/2010 8:11:21 AM(UTC)
