buddha131
#1 Posted : Thursday, May 17, 2012 6:29:32 AM(UTC)
buddha131
When plugging power, I hear a loud buzzing noise at relay overload switch at compressor is this the switch or compressor that is bad? When i unplugged relay the frig just hummed.
buddha131
#2 Posted : Thursday, May 17, 2012 7:36:15 AM(UTC)
buddha131
My overload switch has 3 lead openings,used meter at 2 got 64 ohms other 2 got 0 then top 2 got nothing. touched where the white and red wire are on relay got 0. Got 7to12 ohms at compressor at all 3 leads?
#3 Posted : Friday, May 18, 2012 12:17:29 AM(UTC)
Is the start device a mechanical relay with a coil? If so, you might want to try a new start device available on this parts site.
