Bill Calderon
#1 Posted : Tuesday, May 15, 2012 7:14:37 PM(UTC)
Bill Calderon
About a two weeks ago, i noticed the water tray in the door was full. After dispensing a glass of water, i noticed that several drops of water would continue to come out of the dispenser after the glass was removed. Then two days ago, i noticed the water dispenser flowing water during the refill cycle for the ice dispenser in the freezer, as if the push valve for water was being activated.
This morning, while checking to see what might be causing the water to flow as described, i also noticed that there were frozen water droplets inside the freezer on the door, and packages closest to the door, as if the ice maker was splashing water during the fill cycle. The ice maker does work fine, as does the freezer.
Any one have a clue what the problem is and how to fix it? I would appreciate any help/advice. Thanks.
#2 Posted : Wednesday, May 16, 2012 3:13:35 PM(UTC)
Hi Bill,
What is the complete model number of the refrigerator?
Bill Calderon
#3 Posted : Friday, May 18, 2012 12:24:45 PM(UTC)
Bill Calderon
Hi Bill,
Gene,
Thank you for your response. There were several numbers in the back of the unit, but the one on the receipt reads as follows: PSD243LGRW. The unit is a Performa, and was purchased in 2004. Let me know your thoughts.
Bill
#4 Posted : Friday, May 18, 2012 2:26:48 PM(UTC)
Hi Bill,
There are two water inlet valves in this refrigerator (#17 & #18 at the diagram). Most likely the problem is a bad secondary inlet valve (#17).
- The water inlet valve Part number: 12002193
Here are the breakdown diagrams and Replacement parts for Maytag PSD243LGRW REF - SXS/I&W | AppliancePartsPros.com
P.S. You may want to verify the incoming water pressure. Close the water shut off valve. Disconnect the tube from the primary water inlet valve. Put the tube into a large bucket and open the shut off valve to check the pressure.
Guest (4)
