Schuyler
#1 Posted : Monday, May 14, 2012 6:44:55 PM(UTC)
Schuyler
ordered and recieved recommended part- Use Wpl 22002921
Item Number: AP4028889
Manufacturer's Number: 22002994
Made by Whirlpool
Read more: WHIRLPOOL 22002994 Use Wpl 22002921, AP4028889 | AppliancePartsPros.com
Appliance Parts Pros.com Discount Appliance Parts
there's no terminal/spade connect, for the double green wire (ground wire?
), please advise how to hook this up. or do I need to? is there an adapter?
Simon / APP Team
#2 Posted : Tuesday, May 15, 2012 10:22:44 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Have you checked the part number according the serial number?
If the serial number of the washer starts from 10 to 73 - use the 22002994, if 74 and up - use 22003728.
Thank you.
Simon.
Schuyler
#3 Posted : Tuesday, May 15, 2012 9:10:28 PM(UTC)
Schuyler
Originally Posted by: Simon / APP Team Go to Quoted Post
Hi.
Thank you.
Simon.
Yes, the serial number of the washer starts with 10. and both those part #'s appear to be the same switch and have no provision for the ground wire.
although there are 2 extra tabs in the main connect of both parts, can I hook the grounds up to those post, by putting them into the wiring harness? or can I just leave the ground wires off and install the switch as is?
thanks for any help
Schuyler
#4 Posted : Wednesday, May 16, 2012 12:15:50 PM(UTC)
Schuyler
thanks for any help
since there is no info anywhere on how to install this switch? I just went ahead and installed it, and left the ground wires off (since there is no tab for the ground wires, anywhere). I fired up the machine and so far all is good. the washer fills and drains normally. so I guess the new switch does not need to be grounded??! we will see how it goes from here all is working fine for now.
#5 Posted : Wednesday, May 16, 2012 1:09:23 PM(UTC)
Per the wiring diagram (last page of the Tech sheet), the ground somehow should be connected to the body of the switch. The wires should be connected: gray - terminal 11, yellow - term 12, blue - term 31 and brown - term 32.
File Attachment(s):
16025823 - MAH7500AWW.pdf (581kb) downloaded 2 time(s).
