jonathan8
#1 Posted : Thursday, March 26, 2009 6:00:58 AM(UTC)
jonathan8
The timer does not move from the place I turn it to. whatever tempature the dryer is set at when I turn the knob is the temppature it stays at until I manually turn it off. Is the timer the only thing that could be broken?
#2 Posted : Thursday, March 26, 2009 6:31:35 AM(UTC)
Replacement parts for WHIRLPOOL LER2614DW0 | AppliancePartsPros.com
Here is a tech sheet
https://www.servicematters.com/d...0Sheet%20-%203401728.pdf
No.
Try it in timed dry.
Now does it advance?
Timer gets power from different circuits for timed and auto cycles.
jonathan8
#3 Posted : Friday, March 27, 2009 5:28:22 AM(UTC)
jonathan8
yes it does advance in the timed cycle where do I go from here?
#4 Posted : Friday, March 27, 2009 5:50:12 AM(UTC)
OK, here is the circuit path for the timer motor in Auto cycles
L2 , motor's centrifugal switch 2M/1M , HEATER , RESISTOR , TIMER SWITCH (contacts) OR/TM, TIMER MOTOR , L1
When the heater is turned off by a thermostat, you get L2 voltage at the left side of the HEATER due to no current through it so it does not drop any voltage.
This then powers the TIMER MOTOR through the RESISTOR which drops the voltage from 220 to 120.
Top of the list for possible causes are:
1. The resistor (open)
2. Timer switch (contacts) OR/TM
3. A grounded heater element.
The easiest and safest way to check the above is with a meter.
If you do not have one, I would suggest you purchase a meter. You can get a decent digital multimeter for under $20.00. You do not need fancy though it is nice if the leads are a couple feet long.
jonathan8
#5 Posted : Friday, March 27, 2009 6:00:57 AM(UTC)
jonathan8
Another follow up is that the dial does advance in the timed dry until it reaches the off position. But it stops there and does not shut off.
#6 Posted : Friday, March 27, 2009 6:12:14 AM(UTC)
If the unit has an end of cycle buzzer turn it off.
If it still will not shut off it does sound like you need a timer.
Timer contacts BU/BK may be welded together.
They are the ones that should shut the unit off.
Since you can shut it off manually the contacts may be OK but there could be a problem with the timer's gears.
Guest (6)
