Hi All, hope you can help me. I started running it yesterday, and I heard a clunking noise occurring at the same frequency. I thought that the water jets were hitting some unstable object. Emptied it and reran it, same noise. So I check the rotating arms. The top one is fine, but the lower one has play in it. To be more specific, it has vertical play in it, I can lift it about 1/2 in. Is that normal? I know that that is where the noise is coming from. Any help will be appreciated.
Groups: APP Team
Groups: APP Team
Hi.
Remove the coarse filter#502 on diagram#4. You will see the sump.
Simon.
