lomaxdq1
#1 Posted : Saturday, May 12, 2012 4:00:51 PM(UTC)
lomaxdq1
When I turn on the dishwasher, I can hear the motor run, and when I turn the dial I can hear it change cycles, but it doesn't fill up or spray water. Is it the pump? Okay, more info - since no water is coming in at all, maybe it's the water inlet valve? I am sure that water is available - when I unscrew the hose, water pours everywhere. I really need to fix this thing - my hands are getting chapped from washing dishes!
lomaxdq1
#2 Posted : Saturday, May 12, 2012 4:01:42 PM(UTC)
lomaxdq1
:confused:
#3 Posted : Monday, May 14, 2012 1:38:46 AM(UTC)
I cannot find your model number.
Are you sure that it is not a 04BB instead of a 0488, see the following.
Replacement parts for General Electric GSD3620Z04BB Dishwasher | AppliancePartsPros.com
There can be several causes.
I would check that the float (Item 490 in Section 1) is activating the float (overfill) switch(item 490 in Section 1)
Sometimes due to crud etc. it can get stuck in the up position so the unit thinks it is already full.
If OK check that the fill valve (Item 744 in Section 1) is getting 120 volts when it should be filling.
If it is then either the fill valve is toast or the screen filter on the input side is plugged.
Remove the valve and check/clean the screen filter.
If it is clean replace the valve.
If dirty clean it. Do not permanently remove it as it is there to keep crud out of the valve which would hold it open and cayuse a flood.
If there is no voltage check for voltage (120 volts) across the overfill switch.
If there is voltage then the fill switch is toast.
If there is no voltage then check actross the valve and switch combo (they are wired is series) if there is no voltage then odds are your timer is toast.
GE dishwasher GDT695SSJ0SS middle arm not spinning (Dishwasher Repair)
by merrittjr 3/23/2024 10:51:00 AM(UTC)
GE Dishwasher GDF620HMJ2ES (Dishwasher Repair)
by lou@officenerd.com 1/14/2024 3:32:20 PM(UTC)
GSD5120D00BB GE dishwasher leaking at the bottom corners (Dishwasher Repair)
by ron Minervino 12/7/2023 9:15:11 AM(UTC)
GE Dishwasher Model GDT655SSJ2SS (Dishwasher Repair)
by Dan Jones 11/16/2023 11:33:43 AM(UTC)
GDF610PMJ5ES (GE Dishwasher) - No Power to LED Display (Dishwasher Repair)
by txwildcard 6/7/2023 2:40:51 PM(UTC)
GE dishwasher GDT580SSF5SS water doesn't get hot and dishes are not drying (Dishwasher Repair)
by jmbuffy 5/15/2023 4:45:57 PM(UTC)
GE Dishwasher Loads water but never agitates to clean dishes (Dishwasher Repair)
by Guest 4/19/2023 6:38:21 AM(UTC)
GE Dishwasher, Model: GDF530PGM0WW (Dishwasher Repair)
by Guest 4/12/2023 12:06:40 PM(UTC)
GE Dishwasher GSD900D-02 Door Gasket Gap (Dishwasher Repair)
by DJW000 2/5/2023 10:05:34 AM(UTC)
GE Dishwasher dead UI board (Dishwasher Repair)
by Guest 1/26/2023 9:44:03 PM(UTC)
GE dishwasher - general query about a ball at the back in the tube (Dishwasher Repair)
by delboy1881 7/27/2022 7:49:15 AM(UTC)
GE Dishwasher beeps every 10 seconds (Dishwasher Repair)
by bethH 7/12/2022 3:03:53 AM(UTC)
Ge dishwasher seal replacement (Dishwasher Repair)
by Guest 4/21/2022 5:34:16 AM(UTC)
GE Dishwasher - No Power - Replaced Control Board, Wiring Harnes, and UI Board (Dishwasher Repair)
by aervin 4/19/2022 7:32:28 AM(UTC)
GE dishwasher not filling and other problems (Dishwasher Repair)
by Guest 4/14/2022 3:40:35 PM(UTC)
