My bosch dishwasher will not complete drain cycle. When I try to run diagnostics nothing happens. After cleaning out the filters and replacing the drain float I am still having the same issue. The dishwasher runs with door open and will not complete drain cycle. I am trying to see if I can remove the control panel but I cant seem to get it loose. Any guidance and help trouble shooting this would be greatly appreciated. ~Mike
Check the connection where the drain pump connects into the sink/disposal. If you hear it trickling into your sink, it's going to be a restriction in the pump to the sink. If you have a splitter to make the hose bigger to fit into your disposal, this is more than likely your issue.
After viewing one to many you tub video's. I decided to take apart the front cover and take a peak at the control panel circuit board. I found a bernt mark on the green board that inicated failure. So I ordered a new one. Recieved it in 24 hrs plugged it in. Rehooked everything back up and good as new. Thanks to all.
