rmaxwell
#1 Posted : Tuesday, March 24, 2009 6:00:24 PM(UTC)
rmaxwell
Usually when I turn the oven on knob, the light turns on until oven reaches selected temp. Now when I turn the knob, no light, no heating.
#2 Posted : Wednesday, March 25, 2009 2:18:56 AM(UTC)
Replacement parts for WHIRLPOOL SB130PER1 | AppliancePartsPros.com
Here is a wiring diagram, note it is for a PER5 but should be close to yours.
https://www.servicematters.com/docs/wiring/Wiring%20Sheet%20-%204363496.pdf
I assume that the oven light works, so you know you have power
Could be the thermostat or timer is shot.
Unplug the unit and check it with a meter. I would check the thermostat first.
Unfortunately is shows that this is discontinued, if it is gone you will have to give them a call to see if an alternate thermostat is available.
rmaxwell
#3 Posted : Wednesday, March 25, 2009 5:24:43 AM(UTC)
rmaxwell
Denman, thanks for your input. Called AppPartPro for alternate; order it. Will let you know the results once I get the part and install it. Thanks again.
