I have a Whirlpool Ultimate Care II washer and after it fills with water, it quits. I have been able to pound on the lid door and it will start and the rest of the cycles will finish. However, this is no longer working. Could this be the lid switch? How about the pressure switch.:mad:
If the water shuts off after it is filled the pressure switch should be ok.
Try bypassing the lid switch to check it out.
Originally Posted by: nanc450 I have a Whirlpool Ultimate Care II washer and after it fills with water, it quits. I have been able to pound on the lid door and it will start and the rest of the cycles will finish. However, this is no longer working. Could this be the lid switch? How about the pressure switch.:mad: This is exactly what I'm going through, not alone , with that being said, I will appreciate any help or information in regards to this issue with my very own Whirlpool Altimate ll washer, for starters where's the model # on these boy's. Thank you for your time. evans322
Went Through Exact Same Problem And Replaced Lid Switch But Still Nothing Past Water Fill Up. Any suggestions as to what could be the problem now?
