my washer does not drain or go through the rinse cycle and hear a huming noise, however it does agitate. i have replaced the lid switch and still no change, i also bought a new motor thinkin it was the problem because of smellin hot. well that def wasnt the problem and since i hooked it up its now mine. im at wits end and hoping to find an answer..........what else could this be if any help the model number is lxr6236eq0 thnks for anyones time
i should refraise this it does go through the cycle but dont spin or drain
no one has a response to this?
