:confused: Ice maker isn't making ice. The lever is in the proper position. There is water to the door dispenser. The freezer is freezing. Any ideas or suggestions to get the ice maker working again?
Groups: Senior Expert, Administrators You have been a member since:: 7/19/2007(UTC) Posts: 27,455
Swap the wires between the water inlet valve solenoids. Depress the water dispenser lever for a few seconds and check if there is water in the ice maker. Post the results.
The model number you posted is incomplete. Verify and repost it please.
