Texdel
#1 Posted : Friday, May 4, 2012 1:14:38 PM(UTC)
Texdel
Since we have had this range/oven, the oven has consistently burnt baked goods (biscuits, cookies, etc). Although we have made adjustments, the results were inconsistent and unsatisfactory. I noticed that this model has a setpoint adjustment but I have lost the owner's manual and was only using the service tech bulletin in a pouch behind the range controls.
My initial reading with the oven set for 350F was ~375F with a kitchen oven thermometer (bimetalic strip type). I set the adjustment for -20F and tested again; got a 400F reading. Thinking that I had "gone the wrong way", I adjusted the setpoint for +20F; new reading 450F. Final test was at -30F resulting in a 400F reading. The adjustment is from -30F to +30F in 10 degree increments. The readings were taken after a minimum of 10 min after setting the temperature but the oven was not allowed to cool between tests.
Am I doing something wrong? Why only a +/- 30 adjustments?
#2 Posted : Friday, May 4, 2012 4:48:31 PM(UTC)
Originally Posted by: Texdel Go to Quoted Post
...Am I doing something wrong?...
I'm afraid so. You have to place the thermometer in the middle of the oven cavity. After any adjustments you have to let the oven to cool down at least 50°F bellow a set temperature and then turn it On again. It should stay On for at least 15 minutes after the display showed it reached a set temperature before readings will taken.
