A Lovegreen
#1 Posted : Wednesday, May 2, 2012 9:01:48 AM(UTC)
A Lovegreen
Hi Everyone!
I'm glad I found this forum. This weekend we heard a "pop" on our glass rangetop while cooking breakfast, and when we reset the fuse box (it had blown), we noticed that the red indicator light near the range controller for the warming zone will not turn off, even though we've turned the power off and tried multiple things (turning on the warming zone). Is there a part we need to replace, and, if so, is it easy?
Thanks for your time,
Alan
#2 Posted : Wednesday, May 2, 2012 2:42:37 PM(UTC)
Hi Alan,
Sounds like the problem is a bad control board (aka clock/timer).
- The control board Part number: 316272204
A Lovegreen
#3 Posted : Wednesday, May 2, 2012 3:35:54 PM(UTC)
A Lovegreen
Hi Gene,
Thanks for the link. I've taken a look at the link, but am unsure if I correctly described the location of the light. The light that remains on is actually on the cooktop surface. It is orange, and would normally stay on so long as the range is hot. It is now remaining on despite the warming surface not being on. Would this be linked to the timer/clock?
Thanks for your patience.
Alan
#4 Posted : Wednesday, May 2, 2012 7:06:52 PM(UTC)
Some corrections...
Originally Posted by: A Lovegreen Go to Quoted Post
...we heard a "pop" on our glass rangetop while cooking breakfast, and when we reset the fuse box (it had blown)...
That pop followed by the tripped circuit breaker means there was an electrical short somewhere in the cooktop. Which part of the cooktop did you use when it happened? Did you use the warming zone at that time?
A Lovegreen
#5 Posted : Thursday, May 3, 2012 7:22:20 PM(UTC)
A Lovegreen
I was using two of the main burners and the warming zone when I heard the pop.
#6 Posted : Friday, May 4, 2012 1:57:12 PM(UTC)
Are you able to use any of them now?
A Lovegreen
#7 Posted : Monday, May 7, 2012 9:08:52 AM(UTC)
A Lovegreen
All burners and the warming zone still function normally. The only problem is that the little light to indicate that the warming zone surface is hot never goes off. That light is on perpetually.
#8 Posted : Monday, May 7, 2012 11:53:10 AM(UTC)
Very likely the limiter for this heating element, which is a part of the heating element, is shorted, causing the indicator light to stay On. The correction is to replace the heating element.
- The warming surface heating element Part number: 318198825
Guest
#9 Posted : Tuesday, January 23, 2024 9:12:47 AM(UTC)
Guest
Rank: Guest
United States
It’s brand new, never actually used the stove, was checking to make sure everything worked
Guest (6)
