5 Pages<1234>»
Joe / APP Team
#11 Posted : Wednesday, March 30, 2011 6:24:05 AM(UTC)
Joe / APP Team
Originally Posted by: drew85205 Go to Quoted Post
Received the parts tonight and installed everything, even though no directions where included it was child's play. Ran the self diagnostics and a full load with no problems.
Thanks for all the help.
Drew
Drew,
Great job, (even without the instructions).
We're glad it was an easy repair for you as well.
Assisting you was our pleasure.
Thanks again,
Good Luck,
:D :D :D
away
#12 Posted : Wednesday, May 2, 2012 2:52:25 PM(UTC)
away
Don't know where my post went, I will try again.
I am having same problem ("oL") with my Whirlpool Cabrio Washer (wttw6600sw0). The scenario is that the washer does not stop filling water during Wash cycle, it appears being stuck after Wash cycle begins for 10 mins, hence, overloaded with water. Spin and drain appear OK.
I'd ordered and replaced the RPS kit(AP4327312) even though there was not any sign of leakage nor damage, situation does not improve. I also ordered and replaced its processor/control board (W10189966), no improvement either.
Ran manufacturer's manual diagnostic test (#6) that supposed to recalibrate the water level and Pressure Transducer.
Failed manufacturer's automatic diagnostic test C1.
A Maytag repair person came on site and charged me for a house call, his initial conclusion was that I need to replace the control board (which I did already) and quoted me $400+ to fix it. Upon knowing the board is replaced, he mentioned that the board's memory still needs to be reset. Any truth to this?
Please help!
Thanks.
Away
jamh
#13 Posted : Wednesday, May 2, 2012 4:08:04 PM(UTC)
jamh
Certain models are covered by manufacterer with the c1 error code, call whirlpool.
James
away
#14 Posted : Wednesday, May 2, 2012 4:36:39 PM(UTC)
away
James
Thanks for your reply.
C1 is one of the manufacturer's Automatic diagnostic test steps, C1 thru C9.
Regards.
away
#15 Posted : Wednesday, May 2, 2012 4:43:36 PM(UTC)
away
Regards.
BTW, I did call Whirlpool before, the machine will make arrangement with you in order to dispatch a service call, most likely a visit from your local Whirlpool/Maytag/? repair person.
drew85205
#16 Posted : Wednesday, May 2, 2012 6:15:10 PM(UTC)
drew85205
Did you check the stator for cracks?(common problem) I had the same problem and had to replace the stator and rps(rotor position sensor) What error codes have been logged? In case you dont allready have it, This is the link for the service manual. http://repair2000.com/Library/CABRIOHEWASHER.pdf
drew85205
#17 Posted : Wednesday, May 2, 2012 6:21:28 PM(UTC)
drew85205
I also had to run the recalibration 2 or 3 times before it stopped over loading. It's been fine sence. Does the drum float when filled with water? You should be able to lift the drum up about an inch, make sure it's not stuck in the down position. Also you may want to remove the basket hub and check the lint filter for build up. Page 53 in manual.
drew85205
#18 Posted : Wednesday, May 2, 2012 6:31:41 PM(UTC)
drew85205
Just curious, how much did the service call cost?
away
#19 Posted : Wednesday, May 2, 2012 6:51:09 PM(UTC)
away
Thanks, I've been following this thread and read the manual.
away
#20 Posted : Wednesday, May 2, 2012 6:59:38 PM(UTC)
away
Found no crack , and still I replaced the RPS without any problem.
The error code that was logged: 61.
Thanks, Drew.
5 Pages<1234>»
