Michael Walsh
#1 Posted : Wednesday, May 2, 2012 4:59:32 PM(UTC)
Michael Walsh
The dryer will not turn on. I have checked and there is power to the unit.
The timer is making a little noise but thats it. I think it needs to be replaced part # 53-1810 but want to be sure.
Mike
Simon / APP Team
#2 Posted : Wednesday, May 2, 2012 5:18:46 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Here are the breakdown diagrams and Replacement parts for Admiral LNC7764A71 DRYER- ELE | AppliancePartsPros.com
On the diagram #4 locate thermostat #3 and fuse #5.
Check them both for continuity.
They are sold as a kit Part number: LA-1053
Thank you. Post the results.
Simon.
kayakcrzy
#3 Posted : Thursday, May 3, 2012 3:11:15 AM(UTC)
kayakcrzy
Usually the reason the thermal fuse goes out is because of a back up of lint build-up!! So be real sure, you take the front off of the dryer. Once the top is up on the dryer, you will see a 1/4 inch screw, on the top left corner, on the inside of the front, and one on the right corner. Then pull the front off, I am sure you will see a ton of lint. appliance educator
dryer not running (Dryer Repair)
by SteveDB 2/9/2016 5:18:51 PM(UTC)
Dryer not running (Dryer Repair)
by CComperry 3/3/2014 2:00:38 PM(UTC)
Maytag Performa dryer not running (Dryer Repair)
by bluex 9/19/2013 12:11:15 PM(UTC)
Kenmore Elec Dryer not running on air dry/no heat on all cycles (Dryer Repair)
by jmm53 5/9/2013 11:32:08 AM(UTC)
by Steven R Henderson 12/30/2011 8:06:34 PM(UTC)
Dryer not running!!! (Dryer Repair)
by mjones375 4/11/2011 6:57:05 AM(UTC)
Electric clothes dryer not running! (Dryer Repair)
by jjblum2002 2/2/2010 10:24:03 AM(UTC)
Frigidaire Dryer Not Running (Dryer Repair)
by QuarlJ01 9/23/2009 5:04:41 AM(UTC)
dryer not running thru full cycle (Dryer Repair)
by 30tredog 9/28/2008 5:15:40 PM(UTC)
dryer not running suddenly (Dryer Repair)
by Ellie69 9/26/2008 10:33:28 AM(UTC)
by pwrply2 4/16/2008 5:06:58 PM(UTC)
