13 Pages«<89101112>»
Native Texan
#91 Posted : Tuesday, May 1, 2012 5:38:19 PM(UTC)
Native Texan
Thanks Gene !!
#92 Posted : Wednesday, May 2, 2012 12:10:17 PM(UTC)
gutrunner
#93 Posted : Monday, July 2, 2012 3:09:39 PM(UTC)
gutrunner
Sir,
I have tried just about every check listed in this thread. The motor shows no LED light. It has 120V across back/red and white/red. Even jumped across fuse . Tried reset multiple times. Any other ideas. Washer is 2 years old. Have tech and $79 bill for for checking problem coming tomorrow. Thanks in advance.:eek:
#94 Posted: : Tuesday, July 3, 2012 4:01:22 PM(UTC)
Originally Posted by: gutrunner Go to Quoted Post
Sir,
If there is no LED at all then the motor most likely is bad.
gutrunner
#95 Posted : Friday, July 6, 2012 7:10:06 AM(UTC)
gutrunner
Thanks for reply. GE tech checked and said same thing. Bought another machine, but not GE. GE tech said if I did choose to repair, remove fusable link completely. He said they now bypass that on repair calls. Thanks again for reply and information available on your website.
gbean22
#96 Posted : Tuesday, July 10, 2012 7:07:55 AM(UTC)
gbean22
Gene,
My washer recently stopped agitating and spinning. Seems to fill fine and drain. Bypassed the lid switch, no change, checked the pressure switch, seems to working, and checked the agitator coupling. What else can we do??
#97 Posted : Tuesday, July 10, 2012 3:51:56 PM(UTC)
Remove the front panel and check the status of the LED on top of the motor. Post the results.
Here are the breakdown diagrams and Replacement parts for General Electric WJSR4160G0WW Washer | AppliancePartsPros.com
gbean22
#98 Posted : Tuesday, July 10, 2012 4:53:32 PM(UTC)
gbean22
Do not see a led light anywhere. So I'm assuming its not on.
#99 Posted : Tuesday, July 10, 2012 7:17:19 PM(UTC)
Check the fuse.
File Attachment(s):
Fuse location and diagram.doc (238kb) downloaded 12 time(s).
The signal LED location.doc (541kb) downloaded 15 time(s).
gbean22
#100 Posted : Wednesday, July 11, 2012 2:41:32 AM(UTC)
gbean22
Did that. Can you tell me how much a motor would cost?
Guest (4)
GE washer will fill and drain but no spin/agitate (Washer Repair)
by Montana_Pete 9/12/2008 6:00:02 PM(UTC)
