njbxgirl
#1 Posted : Saturday, April 28, 2012 7:25:12 PM(UTC)
njbxgirl
I have just started noticing that my dishwasher is not drying at all. It leaves tons of water on the dishes and in the washer itself. I have to manually dry them. This has never been an issue before so I am wondering what gives. Just recently installed an electric hot water heater to my home with a new water softener system and am wondering is this the cause because when oil was being used to heat water this never happened. All looks fine inside nothing is cracked or broken so what can be the issue. Please help because my warranty just ran out. Thanks.
#2 Posted : Monday, April 30, 2012 11:22:29 AM(UTC)
Replacement parts for Whirlpool DU1055XTVD1 UNDERCOUNTER DISHWASHER | AppliancePartsPros.com
"It leaves tons of water on the dishes and in the washer itself"
Does the above mean that there is water standing in the bottom of the unit after the wash is finished?
Do you know if the heating element is coming on during dry?
Be careful do not burn your fingers.
njbxgirl
#3 Posted : Monday, April 30, 2012 12:03:37 PM(UTC)
njbxgirl
There is not tons of eater but there is standing water. I did not see any steam coming out on the drying cycle plus no steam when washing. There is usually condisation on the counter and have not noticed that either.
#4 Posted : Tuesday, May 1, 2012 12:51:57 AM(UTC)
You will have to check the heating element (10 to 30 ohms) and the hi-limit thermostat (0 ohms) for continuity.
If both are OK then odds are that the control board is toast.
File Attachment(s):
DU1055.pdf (245kb) downloaded 12 time(s).
Guest (4)
KitchenAid Dishwasher Not drying (Dishwasher Repair)
by louie@DFW 4/8/2022 5:15:51 PM(UTC)
Amana Dishwasher Not Drying The Dishes (Dishwasher Repair)
by mark@homeplanco.com 9/21/2020 7:32:33 AM(UTC)
Dishwasher not drying dishes (Dishwasher Repair)
by Danmrobertson 1/24/2016 9:14:27 AM(UTC)
GE dishwasher not drying dishes (Dishwasher Repair)
by dace109 1/16/2016 10:04:24 AM(UTC)
Electrolux dishwasher not drying after heater replacement (Dishwasher Repair)
by mvmone 7/1/2015 11:37:30 AM(UTC)
Dishwasher not drying, new heating element didn't help (Dishwasher Repair)
by madonid@hotmail.com 6/27/2015 9:34:02 AM(UTC)
Dishwasher Not Drying (Dishwasher Repair)
by tlhiv 11/10/2014 1:27:24 PM(UTC)
Dishwasher not drying - high-limit/temp thermostat or heating element? (Dishwasher Repair)
by tom_in_atl 1/20/2014 7:44:08 AM(UTC)
by J-net 1/15/2014 10:51:32 AM(UTC)
Dishwasher Not Drying Dishes (Dishwasher Repair)
by CMGLAZE 1/1/2014 3:14:43 PM(UTC)
dishwasher not drying but element OK? (Dishwasher Repair)
by hamiltzp 11/26/2013 11:47:37 AM(UTC)
Dishwasher not drying but heating element is good (Dishwasher Repair)
by kgates123 8/30/2012 11:49:19 AM(UTC)
Dishwasher Not Drying and Not advancing from cycle to cycle (Dishwasher Repair)
by Travelcathy 8/12/2012 2:15:38 PM(UTC)
dishwasher not drying (Dishwasher Repair)
by venom79 5/31/2012 8:42:37 AM(UTC)
Dishwasher not drying (Dishwasher Repair)
by frog4060 6/13/2011 4:52:31 PM(UTC)
