bake and broil elements not working. Tech sheet is missing.
Groups: APP Team
Hi. It's not totally clear if there is no sparks at all or only no bake and broil. Let's try to diagnose the no bake or broil situation. Open the control panel, locate the spark module on the left from the main control board. Using the multimeter with oven set to Bake, check for 120VAC at connector P2-4 to ground.Then Broil P2-1 to ground (oven set for broil). No 120VAC - replace the control board. 120VAC present - replace the spark module. The main control Part number: W10116542
Simon,
I have checked P2-4 and P2-1 connectors on the main control and they both have 120v. The spark module has already been replaced and I installed a new suppressor today. The gas valve is the only other thing it could be and that i am not sure about because the four burners on the stove top work.
terminals J3 and J4 have 28v (with bake on, then broil on)
Groups: APP Team
Hi. The safety gas valve works only with the oven. Check the continuity between common- broil and common- bake at the gas valve.If one circuit is open - replace the valve. The safety gas valve Part number: W10293048
Thanks. Post the results. Simon.
