mlab
#1 Posted : Saturday, April 28, 2012 5:00:19 PM(UTC)
mlab
Following a smoke and spark event, my daughter complained the oven wouldn't heat. I could see the bake element was broken. I was about to order a new one, but thought I would pull out the old one first. When I pulled it out, it shorted with a pop and flash. I went down and opened the circuit breaker, then removed the element, and taped the terminals. When I switched the power back on, nothing on the stove worked. It is a Maytag CRE9600CCE. What can it be? A fuse or limit switch or ??? What does it take to fix it. Any help will be appreciated. Thanks == Mike
#2 Posted : Sunday, April 29, 2012 12:55:26 AM(UTC)
Here are your parts, includes a wiring diagram.
Replacement parts for Maytag CRE9600CCE RANGE- S/C F/S ELE | AppliancePartsPros.com
Since the stove top and oven elements are controlled separately and neither work it sounds like a power problem.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
[COLOR="Red"]Be careful as 240 volts is lethal !!! [/COLOR]
A little late, but never pull an element with power to the unit.
On most stoves one side of the element is always connected to 120 volts.
Often this type of spark also blows the control board so I will keep my fingers crossed.
mlab
#3 Posted : Monday, April 30, 2012 6:07:21 AM(UTC)
mlab
I checked the voltage where the pigtail attaches at the stove, and it was 240. Again opened the circuit breaker while I screwed the plate back in place. When I reset the breaker, the clock stove top and broiler all came back. I figure there must have been a loose connection somewhere that moving the range around jostled enough to make the contact. Right now I'm a happy camper, and I'm ordering a new bake element. If it goes out again, I'll double check for loose connections. Many thanks for the advice. Best regards === Mike
#4 Posted : Monday, April 30, 2012 9:00:05 AM(UTC)
I would find the loose connection now.
A bad connection acts as a resistance, as current passes through it heat is generated this further degrades the connection and so on and so on till it fails.
[COLOR="Red"]In other words it is a fire hazard.[/COLOR]
