ceak
#1 Posted : Tuesday, April 24, 2012 7:46:49 PM(UTC)
ceak
:confused: Hi, Washer fills does it's little action before agitation. agitation looks very weak and the tub seems to move some, drains fine and will spin low speed and hi speed. lift the lid during spin and it slows top a stop quick. unpluged and repluged in opened and shut lid the lite blinks no pauses. when put in spin the lite blinks quicker until finished. checked the shaft for continuity and it showed 71 ohms ? Thank You
sidfink43
#2 Posted : Thursday, April 26, 2012 5:04:03 PM(UTC)
sidfink43
If there is a problem with the mode shifter you should be getting an error code from the blinking lights. Since there is no error codes this suggests the motor/inverter may be the problem.
ceak
#3 Posted : Thursday, April 26, 2012 6:18:48 PM(UTC)
ceak
Hi, Thanks for the response. was the ohm reading of 71 within the plus minus area? So could i check the continuity of the motor inverter our even check that theres 120v getting to the motor? i checked the continuity trough the wire harness from timer to motor, would this be a way to check the inline fuse? Thanks Again for Your HELP.:D
ceak
#4 Posted : Thursday, April 26, 2012 6:33:21 PM(UTC)
ceak
Hi, is there a chance of getting a service manual for this washer? VBSR3100G5WW Thanks again
sidfink43
#5 Posted : Friday, April 27, 2012 3:24:43 AM(UTC)
sidfink43
Take a look at this site, it has downloads for manuals. The problem is GE is very tight about releasing technical info.
http://appliancejunk.com/forums/index.php
You may have to join but there is no cost.
