Analu657
#1 Posted : Wednesday, April 25, 2012 10:30:09 AM(UTC)
Analu657
aloha! I just change the latch on the door cause it was broken, then it wouldn't drain, so put back the old water pump, now it works , but it does this fill spin and fill spin cycle for about 10 min. Than it stops What else is going on, we had this washer for awhile already , the only problem was the water pump, which was leaking, so I changed that, then it worked for 1yr, then the latch broke, so I changed that, now this :eek:
Simon / APP Team
#2 Posted : Wednesday, April 25, 2012 1:20:22 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Need more detales on that "fill and spin" thing. On what cycle does it happens?
Also, the model number you provided doesn't come up.
Please check and post.
Thank you.
Simon.
