mcurry
#1 Posted : Monday, March 23, 2009 2:56:18 PM(UTC)
mcurry
the water will not pump out of the diswasher. if i suck out the water and start the machine it will start a cycle and keep running and when its done the water is in the bottom and never pumps out.
ge does not seem to be of much help except that they will send someone.
#2 Posted : Tuesday, March 24, 2009 5:11:31 PM(UTC)
The first thing I would do is remove the toe panel and check the drain line from the one end to another one. Check the air gap on top of the sink (if there is one).
Here are the break down diagrams and Replacement parts for GE PDW7380J10SS | AppliancePartsPros.com
