cowboy
#1 Posted : 13 years ago
cowboy
This is a GE Profile refrigerator and has happened twice in the last four months. The interior lights stay on when the door is closed. To troubleshoot I found that when the door is open and the door switch is pushed closed by hand the interior lights do not turn off. Several pushes of the door switch by hand finally turn the lights off. Is this a faulty door switch or is there a relay or some other component that is not working properly?
Simon / APP Team
#2 Posted : 13 years ago
Simon / APP Team
Groups: APP Team
Hi.
The refrigerator section door switch should be replaced.
The door switch Part number: WR23X10530
Here are the breakdown diagrams and Replacement parts for General Electric PSC23SGRCSS Refrigerator | AppliancePartsPros.com
Thank you. Post the results.
Simon.
vickiellen
#3 Posted : 7 years ago
vickiellen
Simon or apliance repair please correct the solution to this question. I have the same problem the lights STAY ON WHEN THE DOOR IS SHUT. Heats up the interior of the refridgerator. The freeer is fine. What do I need to correct the light staying on while door is shut?
