tang163
#1 Posted : Monday, March 23, 2009 10:47:01 AM(UTC)
tang163
Washer fills then mostly empties, then fills again. This happens more than 10 times. The washer then goes to the next cycle without agitating
#2 Posted : Tuesday, March 24, 2009 1:54:34 PM(UTC)
Where and how high the drain hose goes?
tang163
#3 Posted : Wednesday, March 25, 2009 6:15:22 AM(UTC)
tang163
The drain is 4 feet aove machine. However, this is a new problem. The machine has run OK for years. It has been sggested to replace the wter level switch.
#4 Posted : Wednesday, March 25, 2009 12:33:04 PM(UTC)
Does the pump run when it empties?
gene.
