seltzd
#1 Posted : Thursday, April 19, 2012 6:13:43 AM(UTC)
seltzd
Anyone?!?!?!
I have a Thermador and here are the problems. Oven, griddle and broiler dont always light. Oven lights stay on when oven on and off when oven off. Cant turn off and on with switch. Oven indicator light does NOT light, but heating and clean indicator lights do work. (Fault indicator uses oven and heating indicator lights, so all I get in my fault is the second half, the heating indicator light.) My fault is three blinks. I have replaced the PC board with no change. Any ideas?????
THANKS!
Simon / APP Team
#2 Posted : Thursday, April 19, 2012 12:53:08 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
You need to do several things.
First - the oven thermostat/potentiometer and the selector switch should be replaced.
Then you need to check the air switch and cooling fan performance.
Then - test the door switch and the light switch (continuity test).
With all those things done you should be able to illuminate the problem.
The oven potentiometer Part number: 624610
Part number: 624610
The selector switch Part number: 623837
Part number: 623837
The light switch Part number: 418325
Part number: 418325
The door switch Part number: 418323
Part number: 418323
The air interlock switch Part number: 415050
Part number: 415050
Here are the breakdown diagrams and Replacement parts for Thermador PGR364GDZS | AppliancePartsPros.com
Thank you. Post the results.
Simon.
PS. You can return all unused parts even if they been installed.
seltzd
#3 Posted : Sunday, September 16, 2012 7:53:10 AM(UTC)
seltzd
Well, it took me a while to order parts (bad economy and all). I replaced the selector switch and oven potentiator and all seems to be good for the oven (although my default indicator still blinks) But now my griddle is not working. ???? Igniter works, seems like no gas coming thru line.
Simon / APP Team
#4 Posted : Monday, September 17, 2012 11:13:52 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Check the gas solenoid Part number: 418064
Guest (4)
