machovoe
#1 Posted : Sunday, March 22, 2009 5:27:29 AM(UTC)
machovoe
My wife was doing a small load in the machine when it just stopped working like it was not connected to the power. I checked the line and it was plugged in and I checked the circuit breaker and it was not tripped, and I finally connected it to a heavy duty extension cord with the same results. My next guess would be that perhaps there is a circuit breaker in the machine.
Can anyone help me????
Don
#2 Posted : Sunday, March 22, 2009 7:05:31 AM(UTC)
Here is a service manual
https://secured.whirlpoo...c5d004632a4?OpenDocument
Here is a tech sheet
https://www.servicematters.com/d...0Sheet%20-%208530142.pdf
You could check for a loose connection somewhere.
To go any further you will need a multimeter.
This is a fairly complex piece of gear.
Hopefully someone else has some input.
machovoe
#3 Posted : Sunday, March 22, 2009 6:54:35 PM(UTC)
machovoe
Thanks for the quick reply. After I wrote my message I went back to loo at the machine and found that I did have power when I accidently pressed one of the function buttons. Now I noticed that me real problem is a code of LD which I looked up and it suggested that there was an obstruction in the drain system and it was most likely in the drain pump which may be full of lint and whatever. The issue now is getting to the pump as I removed th access door but did not see the device hat was illustrated in the instructions
