AppliancePartsPros.com
Appliance Repair Help
Dishwasher Repair
Whirlpool Quiet Partner III blinking sanitized light
The Sanitized light is blinking after the dishwasher is finished. The dishes are clean but very wet. Any idea what is wrong?
Could very well be a bad drying element. Tom
Here are your parts Replacement parts for WHIRLPOOL GU1200XTKQ0 | AppliancePartsPros.comHere is a service manual https://secured.whirlpoo...520548/$FILE/8178022.pdfCheck the heater and the high limit thermostat If you do not have one, I would suggest you purchase a meter. You can get a decent digital multimeter for under $20.00. You do not need fancy though it is nice if the leads are a couple feet long. If it saves ordering one unnecessary part it has paid for itself and you end up owning a useful tool. Most places will not let you return electrical parts so if you order it, you own it. A couple things to watch when measuring ohms and continuity 1. Always remove power from the machine otherwise you could blow your meter. 2. Always disconnect at least one side of any device you are checking. This eliminates the possibility of measuring an alternate/parallel circuit path. 3. When checking for closed contacts and continuity use the lowest scale (Usually 200 ohms). Then try higher scales. This scale is 0 to 200 ohms so if the device you are measuring is 300 ohms this scale would show an open circuit which it is not, you are just measuring outside the scale's dynamic range. There is a good STICKY at the start of this forum about it's use. |
THIS FORUM IS DEAD!!!!!!! |
Dishwasher Repair
