joel.k
#1 Posted : Tuesday, April 17, 2012 9:04:24 AM(UTC)
joel.k
washer filled up then stopped. briefly smelled acrid/burnt odor. no other settings on the timer work. washer seems "dead". some folks say the timer is bad others the lid switch. thoughts??
Simon / APP Team
#2 Posted : Tuesday, April 17, 2012 10:31:47 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
You need to do some continuity tests.
Using the multimeter (with washer unplugged) at the water level switch check for continuity between V - T (with washer full with water).
No continuity - replace the water level switch.
The water level Part number: W10337780
Next - check the timer.
Remove the plug from the timer,set timer for normal wash,
pull out the knob.
There should be continuity at BK - V, Y - BU, R - BU, T - BU.
If any contacts are open - replace the timer.
The timer Part number: 3951702
Here are the breakdown diagrams and Replacement parts for Whirlpool LSB6200KQ0 WASHER | AppliancePartsPros.com
Thank you. Post the results.
Simon.
