elbebe2525
#1 Posted : Monday, April 16, 2012 2:14:42 PM(UTC)
elbebe2525
why my oven does not turn on?what can i check?i may need it for this weekend:(
Simon / APP Team
#2 Posted : Monday, April 16, 2012 3:04:43 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
. The most common problem is bad oven ignitor. Do you see the ignitor glow when the oven turned on?
If it glows you need to check the Amp draw, using the amp meter. If it less then 3.25 Amp - replace the ignitor.
If it's not glowing, check the continuity across the two ignitor leads. If the ignitor is open - replace it.
The bake ignitor Part number: 98005652
Her are the breakdown diagrams and Replacement parts for Whirlpool SF310PEKQ0 GAS RANGE | AppliancePartsPros.com
Thank you. Post the results.
Simon.
elbebe2525
#3 Posted : Monday, April 16, 2012 4:31:43 PM(UTC)
elbebe2525
thanks for reply , ill order the ignitor today as soon as i get it ill replace it , ill update results, thanks!!!;)
Simon / APP Team
#4 Posted : Monday, April 16, 2012 5:29:27 PM(UTC)
Simon / APP Team
Groups: APP Team
You are welcome.
Simon.
