zhtway
#1 Posted : Monday, April 16, 2012 11:01:05 AM(UTC)
zhtway
My Whirlpool Cooktop Scs3617 has four burners. I use baking soda soak in water and clean up yesterday. I use alot of waters and spill over the burner units. And also powders are clot and spill over it. Ignitors are also wet. I let those burners dried out and remove those powders. There may some remains.
Now after 6 hours, only one burner work.
When I turned on other burners, I heard clicking sounds and see sparks from the working one as well. I think electrodes are in parallel.
I assume that ignition module is still OK bcoz one is still working.
Any thoughts or suggestion will be greatly appreciated.
Simon / APP Team
#2 Posted : Monday, April 16, 2012 1:04:32 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
The model number that you provided is incorrect.
But in general in you case clean the ignitors from any foreign materials, clean the burner opennigs, using a pin or needle.
Let everything dry for 24hrs before using.
Thank you. Post the results.
Simon.
zhtway
#3 Posted : Monday, April 16, 2012 1:19:58 PM(UTC)
zhtway
Thanks for your reply.
Actually, I couldn't check on the appliance. But i have manual left from the previous owner and it is close to scs3617 (30") one.
Here is the image I found on I'net. It is similar to mine and model is scs3017.UserPostedImage
Simon / APP Team
#4 Posted : Monday, April 16, 2012 5:20:46 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Try first what I suggested and post the results.
Simon.
zhtway
#5 Posted : Tuesday, April 17, 2012 8:59:00 PM(UTC)
zhtway
Hi Simon,
You are right.
I cleaned up thoroughly and all are ok now.
Simon / APP Team
#6 Posted : Tuesday, April 17, 2012 11:12:54 PM(UTC)
Simon / APP Team
Groups: APP Team
You are very welcome.
Simon.
Guest (4)
