Avenger9
#1 Posted : Saturday, April 14, 2012 11:13:09 AM(UTC)
Avenger9
Found water leaking down the right side of the unit during what I think is the wash portion of the cycle- couldn't figure out exactly where it's coming from until I pulled the unit out and off the soft blanket/covering. Seems to be coming from around whatever vent(?) that's at the top of the unit? Pics taken an hour or two after a cycle.
UserPostedImage
UserPostedImage
Is this in a normal position?
UserPostedImage
UserPostedImage
Any help greatly appreciated. Thanks.
#2 Posted : Sunday, April 15, 2012 2:12:53 PM(UTC)
This is the upper spray nozzle feed tube.
Odds are good that the gasket is shot
Part number: AP2109646
There seems to be some confusion on the size.
The grid is one inch squares.
Click on the picture and a new page will open with a Q&A section.
Carefully check that the feed tube is not cracked.
Avenger9
#3 Posted : Sunday, April 15, 2012 7:14:48 PM(UTC)
Avenger9
Thank you. I went ahead and unscrewed the spray nozzle, flipped the gasket over and screwed it back together - it's possible it was just loose? Gasket didn't look *that* bad - but we'll find out if that fixed anything on the next cycle. Thanks again.
#4 Posted : Monday, April 16, 2012 3:08:00 AM(UTC)
You are welcome.
I will keep my fingers crossed.
And thanks for getting back to us, now when people search for the same problem they will see what actually fixed the problem instead of just suggestions on fixing it.
Avenger9
#5 Posted : Tuesday, April 17, 2012 7:11:16 PM(UTC)
Avenger9
Follow up: seems to be good to go, no more leak. Whether it was the gasket needing to be re-seated or just tightened down - don't know. All I know is I don't think I could've brought myself to pay $23 for a friggin' gasket!!! ;-)
