need part for compressor it is a plug that goes on the compressor like a big plug with some kind of relay
Part 119 on your unit parts diagram is the overload relay. It says it's out of stock.
But there is 2 parts on the web site that have the same # 119 but one comes with the controller assembly and the other is just the overload. what i wood like to know is what is the difference in shape if any on these 2 parts if there is none then I would like to buy the part that is in stock because there was one in stock. here are both part numbers one is just the overload # AP3427658 and the other one is with the controller assembly and over load # AP3427658. AND THANKS FOR THE REPLY.......
On this parts site it calls for an overload item AP3423386 . This is the overload and start device in one box. Shows out of stock. Sears parts site shows part #WR08X10037 it is listed as available.
