7 Pages123>»
carobe
#1 Posted : Wednesday, November 28, 2007 5:11:03 PM(UTC)
carobe
My analog clock/timer died on my GE double built-in oven. I ordered the replacement part WB19X10006 and installed it. The only problem I have is that the bottom oven will no longer clean. The SET light comes on; the CLEANING light comes on. But TEMP light does not come on; LOCKED does not come on; and oven never starts heating. The top oven works as it should. Is there a setting on the new part that has not been addressed for a built-in double oven??? Can anyone help me get my appliance back in the A1 condition it was in before the clock went out?
#2 Posted : Wednesday, November 28, 2007 7:36:22 PM(UTC)
Does this oven work in a timed cook mode?
If it does not, then possible a miswiring for the lower oven.
carobe
#3 Posted : Thursday, November 29, 2007 6:41:54 AM(UTC)
carobe
Gene, Thank you for your prompt reply.
The oven DOES work in timed mode.
#4 Posted : Thursday, November 29, 2007 10:26:51 AM(UTC)
Check the door latch and switches on the door latch.
carobe
#5 Posted : Thursday, November 29, 2007 10:45:49 AM(UTC)
carobe
Latch and door checked and are fine. By the way, this oven worked fine in all modes including self-cleaning prior to installation of this part.
#6 Posted : Thursday, November 29, 2007 1:24:04 PM(UTC)
In such situation possible you have the new clock defective.
You have to contact the place where you purchased from for a warranty replacement.
carobe
#7 Posted : Friday, November 30, 2007 4:56:39 PM(UTC)
carobe
Gene,
Thank you for all of your responses. I have requested a new part and if it works, that will tell us that the 1st one I received is defective and I will be mailing that one back
#8 Posted : Friday, November 30, 2007 5:02:51 PM(UTC)
when you will install the new one, be very careful with wires and follow the installation instructions step by step.
carobe
#9 Posted : Friday, February 1, 2008 12:39:17 PM(UTC)
carobe
The WB19X1006 Digital Electronic Timer replaced the following: WB19X0142, WB19X5269, WB19X5231, WB19X5282, and WB19X5223. Based on that, it seems that this part would NOT be the replacement for your part. My oven is GE Model JKP36. As you saw by the threads, we did receive another part to determine if the first one was defective. It did the same thing - everything works EXCEPT cleaning the bottom oven. I finally called GE repair and a repair technician came out and spent 2 days - and could not solve the problem. This oven is 22 years old; well, the technicians have never seen this model nor the inner workings of it!!! He did consult a retired expert, who gave him a few suggestions, but to no avail. I tell you this because you may run into the same problem as far as the age of the technicians are today and the changes made in the product. Good Luck
soundlab1407
#10 Posted : Wednesday, June 11, 2008 11:02:56 AM(UTC)
soundlab1407
carobe,
I'm replacing the old mechanical timer in my single GE wall oven with the WB19X10006 digital timer. I was concerned that the old timer has connections to only 3 of the 5 terminals: L1, Output 1, and neutral. L2 and Output 2 have no connections. Based on your post, I'm wondering if L2 and Output 2 are for the second oven.
Gene: any thoughts?
Thanks,
Tom
Guest (12)
7 Pages123>»
