JStoia
#1 Posted : Friday, March 20, 2009 8:50:29 AM(UTC)
JStoia
I have a problem with the door closing properly on my GE TFX22RNA refrigerator and believe the cam is damaged / worn out. We found small pieces of plastic on the floor just prior to noticing the problem.
What I need to know is how many parts should I be replacing? I would like to order what is suggested, so I can eliminate not getting all parts needed to fix the problem.
The Cam Riser (AP2058495) and Shim Cam (AP2059405) are what I believe would fix the problem. Can you think of any others prior to me placing the order?
Thanks in advance.
Jim
woodchuckie
#2 Posted : Friday, March 20, 2009 8:59:33 AM(UTC)
woodchuckie
The cam riser is all I've ever had to replace.
