mbdbruce
#1 Posted : Friday, March 20, 2009 6:14:00 AM(UTC)
mbdbruce
When we bought our new house (new to us but, older home) we received all maytag appliances that were only two years old. Well when the power went out the first time the ice maker in the fridge had to be replaced because it stopped working. Now yesterday the power went out and the oven is now having issues! Everything on the oven is working i.e (stove top, broil, delay, cook and hold, keep warm, clock, adjusting temp etc.). But, when you turn the oven say to 450 degrees or any temp and hit bake the oven clicks as it always has and the current temp of the oven shows 100 degrees. After about 45 minutes to one hour it will only be at 235 degrees. The broiler works great but, the oven will not heat up properly! Please help!:eek:
kayakcrzy
#2 Posted : Saturday, March 21, 2009 7:18:18 AM(UTC)
kayakcrzy
Sounds like you have a bad bake element. That is the one on the bottom. The reason you get some heat is because the broil element is coming on a little, because of voltage bleedback which is normal. I would say replace the element, but before you do so, make sure there are not burn't wires going to it. Ofcourse you do this with the power cut off. The part # is 74011117. Tom
#3 Posted : Sunday, March 22, 2009 2:43:58 AM(UTC)
Replacement parts for MAYTAG MER5755QAW | AppliancePartsPros.com
Here is a service manual and a tech sheet
http://www.servicematters.com/m...ibrary/docs/16025644.pdf
http://www.servicematters.com/m...ibrary/docs/16025646.pdf
The easiest and safest way to check it is with a meter.
Checking it for resistance with the unit unplugged
If you do not have one, I would suggest you purchase a meter. You can get a decent digital multimeter for under $20.00. You do not need fancy though it is nice if the leads are a couple feet long.
kayakcrzy
#4 Posted : Sunday, March 22, 2009 4:35:04 AM(UTC)
kayakcrzy
Let us know what you found. Tom ApplianceEducator.com
