Aida Cordon
#1 Posted : Wednesday, April 11, 2012 5:39:59 AM(UTC)
Aida Cordon
Hi, could anyone please tell me if it would be possible to substitute the control panel on a Kitchen Aid dishwasher model KUDS01IJWH1 for the control panel of a Kitchen Aid KUDS01ILBT3. Will the control panel of a KUDS01ILBT3 work on the KUDS01IJWH1. I live outside the US and the control panel of my KUDS01IJWH1 is not working and the only control panel I've been able to find is a KUDS01ILBT3. Will it work? Thank You
#2 Posted : Wednesday, April 11, 2012 6:02:40 AM(UTC)
If I look up both model numbers on AppliancePartsPros the control boards are the same AP3775506 (8564543) so they should be the same.
As long as you are sure that it is a control board problem then you should be OK.
Note that the board is fused and also control panel problems can look like control board problems.
Aida Cordon
#3 Posted : Wednesday, April 11, 2012 8:30:45 AM(UTC)
Aida Cordon
denman, thank you so much for your help.
