i need to know how to wire up the motor.the wires where pulled off.
can someone please help me i need the wiring diagram
If you look at the last page of the parts list, it contains the wiring diagram with the pin connections for your motor.
I have a CDE20T6W schematic diagram if you could use, I can scan it to you.
Originally Posted by: jimhethr i need to know how to wire up the motor.the wires where pulled off. I have the schematics for a Crosley dryer Model CDE20T6W. If you need it I can scan it to you. This is my second posting because I think the first one did not go thru. Narapni
I have a CDE20T6W schematics. If it helps I can scan it to you.
Narapni
yes please send it. thank you
Sorry to bother but I think the technician already gave you the answer. Good luck.
