2 Pages12>
fastrat37
#1 Posted : Thursday, March 19, 2009 7:19:26 AM(UTC)
fastrat37
this dryer has had this symptom since we bought it. When it first started to "act up" it would start working after it had time to cool off it seemed. then it would work normally, but now it has stopped working altogether unless you hold down the start button, but no heat. Heating element was replaced about a year ago..........:confused: I have jumpered all the switches I could find that had 2-wires and still nothing. The door switch has 3-wires going to it......which wires do I jumper together to bypass the door switch? I beleive they were white, blue and brown.
#2 Posted : Thursday, March 19, 2009 8:28:39 AM(UTC)
Here is a tech sheet
https://www.servicematters.com/d...0Sheet%20-%203979101.pdf
Door switch is white to blue
Here is a good site with additional info
http://www.applianceaid.com/whirlpool-dryers.html
Especially #40
On your unit look at the lower left hand corner, it shows the PTS switch (push to start), the board then senses this and activates the Motor Relay which keeps it running.
I would suggest you purchase a meter. You can get a decent digital multimeter for under $20.00. You do not need fancy though it is nice if the leads are a couple feet long.
fastrat37
#3 Posted : Thursday, March 19, 2009 12:18:15 PM(UTC)
fastrat37
I already have a Fluke 83 so I will start testing components as I go through the Tech sheet tests............stay tuned.
fastrat37
#4 Posted : Thursday, March 19, 2009 5:00:56 PM(UTC)
fastrat37
I have tried to perform the "Factory Test" as per the tech sheet.......it will not enter the "Test Mode" and NO beep is heard......is this any indication of an Electronic Control Assy. problem/failure??:confused: Do I need to go any further in the testing of other components now?
Thanks in advance for the help you have already given me, it is much appreciated!!
#5 Posted : Friday, March 20, 2009 4:05:11 AM(UTC)
It does look like the board is shot but I would do the other tests/checks on the 48 volt DC and the thermistor.
You want to narrow it down as much as possible before getting a replacement board.
fastrat37
#6 Posted : Friday, March 20, 2009 5:45:21 AM(UTC)
fastrat37
To get to the motor relay to check for the 48 vdc, how much of the dryer do i take apart? I can see part of the motor looking in thru the bottom access panel behind the duct work.........do I take off the side or do I have to remove the drum?
#7 Posted : Friday, March 20, 2009 10:27:51 AM(UTC)
As far as I know it is all in the control console
fastrat37
#8 Posted : Friday, March 20, 2009 1:24:05 PM(UTC)
fastrat37
Went to the Sears parts store and researched the electronic control assy. It is $121 plus shipping and not in stock, so I am going to be into this repair half the cost of a new dryer at Sears..........hmmmmm, I am leaning towards the new dryer for now............I could go craigslist.org and get one with other problems and no warranty.
#9 Posted : Friday, March 20, 2009 2:29:26 PM(UTC)
I agree with you putting in half the cost of the dryer does not make sense.
Especially when you see the Appliance Aid website has a special section just for Even Heat Controls usually means there is a higher than average breakdown rate.
Went to the Sears site they list the board as 8446229, then crossed it to Appliance Parts Pros came up with AP4319168 at $55.69.
fastrat37
#10 Posted : Friday, March 20, 2009 5:03:52 PM(UTC)
fastrat37
I just ordered the part from App. Parts Pros........with shipping, the order was under $61.00.........I really didn't have $325.00 for a new dryer or their inflated part price@ Sears......I sincerely appreciate your efforts in looking up the part and finding it at a reasonable price!! I will have to get out the clothesline for a few days.............I will make sure to post the results after I change out the circuit board:)........Mike
Guest (4)
2 Pages12>
