KB123
#1 Posted : Wednesday, November 28, 2007 10:12:20 AM(UTC)
KB123
MY GE side by side frige has had the defrost heater asembly replaced recently and now has a different problem. It is too warm on the top and freezing on the bottom on both sides. I checked the owners manuel and adjusted temp with no reults. I took apart the freezer side again and the fan was not running. When I tapped it with my finger it started on 2 different occaions last night. the ice maker and water dispenser is not working at the moment I think because the water tubing at the bottom of the frige is frozen right next to the frozen veggies in the crisper. What parts do I buy?
kooler
#2 Posted : Thursday, November 29, 2007 8:43:07 PM(UTC)
kooler
Without proper airflow you will have inconsistent temps.. Suggest replacing evaporator fan motor (AP3191003) if it runs after tapping on or around it..
