modernist
#1 Posted : 16 years ago
modernist
Just replaced both water inlet valves yet water dispenser still drips somewhat. Any suggestions? thanks
woodchuckie
#2 Posted : 16 years ago
woodchuckie
Disconnect the water line coming out from the new water valve to make sure the problem is not with the new valve. Try the dispenser to see if the water stops there where you have it disconnected. There is a strainer before the valve that may need cleaning and some sediment could have stopped up the new valve.
#3 Posted : 16 years ago
Just to add my 2 cents... Drain 1 or 2 gallons of water though the water dispenser to get rid of air in the system.
Water Dispenser Dripping (Refrigerator & Freezer Repair)
by Loribeth 8 years ago
Kenmore Coldspot Water Dispenser Dripping (Refrigerator & Freezer Repair)
by GlobalGramma 13 years ago
Throught the door water dispenser dripping (Refrigerator & Freezer Repair)
by rgeronimo01 14 years ago
by Carr Boy 17 years ago
