I'm trying to find a replacement cooktop for my Maytag Gemini stove, the modle number is mer6875aas and the part that I need is:
74010033 / 5706x509-09
If anyone knows any sources where I could get that it would be appreciated. This appears to be a discontinued part.
I have checked with five different parts distributors. The part is no longer available through the original manufacturer. No authorized substitutions have been identified.
Hi there
My glass is broken as well, same model stove. Have you had any luck sourcing the glass top?
Thanks!
Doug
Mine is broken as well. Have you had any luck sourcing the glass top? I have searched everywhere, no luck
SCHOTT CERAN is the manufacturer of the actual glass top, but they won't sell me the glass top because it needs to be sealed into the frame by an appliance repair expert. Ideas? Stove is junk without the top [MODEL]Maytag MER6875ACS range
