dutchreagan
#1 Posted : Thursday, April 5, 2012 6:46:53 AM(UTC)
dutchreagan
There is water trickling from the vents at the back of my freezer compartment and forms ice in the bottom. Also, it occasionally leaks water onto the floor in front of the unit. I have seen the previous posts and believe it to be a clogged condenser tube (my condenser pan is bone dry). I found the bottom of the tube; however, I can't find the drain opening inside. The freezer is on the bottom with french doors at the top for the refrigerator.
#2 Posted : Friday, April 6, 2012 1:49:21 AM(UTC)
It is probably right under the evaporator coils.
I did find a manual for you but cannot download it as I have reached my daily limit of 6 manuals from this site, so I cannot gewt it to see if it will help you.
Here it is.
http://appliancejunk.com/forums/index.php?action=downloads;sa=view;down=335
