lovenmygirls
#1 Posted : Wednesday, April 4, 2012 5:28:39 PM(UTC)
lovenmygirls
Hi.
i bought this Jenn-Air Oven off Craigslist for $100. Great deal right? Well now that it is installed, I have noticed the display is SUPER dim (can't even see it unless it is dark in the house) and the doors won't stay closed...The oven works, I just need help with these 2 things.
Is it something I can fix ( I know ZIP about ovens),
or should I hire someone? :confused:
Thank you!!
Monica
#2 Posted : Thursday, April 5, 2012 2:58:22 AM(UTC)
Replacement parts for Jenn-Air JJW8630CAB WALLOVEN- S/C ELE | AppliancePartsPros.com
Here is a service manual.
http://appliancejunk.com/forums/index.php?action=downloads;sa=view;down=414
Dim Display.
You have 2 options:
1. Replace the display (Item 3 in Section 2).
2. Try fixing the board. There is no guarantee that this will fix the problem but it is a lot cheaper than replacing the board so if you or a friend has experience soldering electronics it may be worth a try. What happens is that over time the electrolytic capacitors in the display power supply dry out/fail and it then does not get the correct voltage. Note: It is important that the polarity of the replacement capacitors be the same.
Following is a link to a post about this problem.
http://forum.appliancepartspros...n.html?highlight=display
Door Closing.
Not sure if this is a single or double oven so have included both kit numbers.
Try removing and re-installing the door, sometimes it is just not mounted correctly.
Does look like they have had problems with these units, see the below kits.
Issue: Door not closing/Door not engaging light switch.
Action: The following kits will contain Hinges, Hinge Assembly Receptacles, and Instruction Sheet
• Install kit number for single and combo units.
Part number: AP4009106
• Install kit number for double units.
Part number: AP4008676
Click on the picture for more views and info.
