srittinger
#1 Posted : Tuesday, March 17, 2009 11:05:21 PM(UTC)
srittinger
Hi! Can anyone help? I have an 18.2 cu ft reefer that had a horendous smell-- it had been turned off with rotten stuff inside. I have cleaned it thoroughly with bleach, antibacterial cleaner and baking soda but it retains a slight odor which I think may be coming from the styrofoam "diffuser" blocks in the panel in the top of the fridge compartment. They may have absorbed the odor. Is this possible and would replacing them help? Are they difficult to replace? Any other suggestions to eliminate the lingering smell would be greatly appreciated! Thanks.
kayakcrzy
#2 Posted : Wednesday, March 18, 2009 3:41:33 AM(UTC)
kayakcrzy
Sometimes charcoal brickettes, or vanila extract, obsorb a good amount of odors. Tom ApplianceEducator.com
#3 Posted : Wednesday, March 18, 2009 4:30:01 AM(UTC)
Here your parts
Replacement parts for FRG FRT18KG3CW0 | AppliancePartsPros.com
Items 12 & 13 in the 4 Shelves section.
Here is a parts breakdown which should help you take it apart
ftp://ftp.electrolux-na.com/Pr.../Anderson/5995388468.pdf
It is possible but without being there cannot say for sure. Did you flush some of the 10% bleach solution down the drain. White styrofoam will absorb odors as it is open cell. Soaking them in a 10% bleach solution should get rid of it as they will also absorb the bleach solution.
Also did you clean the drip tray under the unit and flush the defrost drain with the leach solution? Smells from the drip tray would apply if you can smell it with the doors closed especcially if it is stronger when the compressor is running.
Not that difficult see the above parts breakdown. If possible you only want to drop it enough so you can replace the parts so that nothing is pulled loose.
Putting the unit outside in the hot sun with the doors open for a couple days often can get rid of smells. Just have to be sure that a kid cannot climb inside. Leaving all the racks etc. in should discourage this. Also tying the doors open.
Sometimes no matter what you do the smell will linger for a long time!!!
srittinger
#4 Posted : Wednesday, March 18, 2009 8:26:58 AM(UTC)
srittinger
Thank you very much for your suggestions. I will try to check the drain and collection pan and if the diffuser blocks are not too difficult to remove, I may try soaking them in bleach solution. They are only $10 for new ones but I'd have to remove the old ones anyway.
Drags1998
#5 Posted : Wednesday, March 18, 2009 11:22:07 AM(UTC)
Drags1998
THE ONLY thing that I have found that will work is FRESH GROUND COFFEE, spread some on a dish and put it in both sections, leave it 3 days and repeat again!!!! This should take care of it!!!!!!!:)
#6 Posted : Tuesday, March 31, 2009 8:09:52 AM(UTC)
Drags1998
Let my son in law use the cabin for some ice fishing and snowmobiling.
He left some meat in the freezer section which of coarse went bad and caused a stink.
Wife and daughter went to the lake and used your coffee grounds method.
She called today to say it worked like a charm.
Thanks for the great tip
Guest (5)
